2006 jetta tdi brm - black smoke / hesitation in 1st - please help
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by TDIwtf, Feb 25, 2012.
  1. TDIwtf
    TDIwtf New Member
    Feb 25, 2012
    2006 Jetta TDI BRM
    Ok so just as a side note I have been researching this issue for months - there are a lot of posts relating to my issues however the final solution is not there....If anyone could shed some light it would be much appreciated.
    My car is having some major issues in 1st gear - Its like its waiting to kick in ... like i have to hold down the pedal and hop it takes off or let off and apply pressure again. When I do this I get a huge could of black smoke......the car does not do this everytime tho......so here is what ive done to fix the issue
    1. EGR Motor
    2. Fuel and Air Filters ( NOT K&N just stock )
    2. MAF Sensor
    3. Cam Shaft
    4. Timing Belt
    5. Turbo
    6. Cleaners / Addiives bla bla bla
    I just had the turbo done last week and yet again the problem is back ... its so hard to look the mechanic in the face without wanting to smash it in ! These "VW" pros are driving me crazy.
    My bank account is drained and Im at my wits end ... the car isnt even paid off yet.....So if anybody has the solution please let me know!!!!!!!!! Thanks wes.tarry@yahoo.ca
    23,901
    To start with, what error codes is it producing? Are you doing all of the work yourself or paying someone else to do it? Because if timing belt is messed up than it'll cause a whole host of probs.
    Is the car DSG or manual?
  3. nord
    nord New Member
    Oct 29, 2011
    18
    Mk5 Jetta '06
    Black smoke is a sure sign of too much fuel or too little air. Given that this was happening before the cam and the other work, at least you've eliminated that much. I guess I'd start by saying that since it's either fuel or air, you have to decide which one to go after first. I'd likely start with air.
    You mentioned turbo in your post. New turbo? If not, then what was done? I'd like to see what things look like on the VagCom. My guess is that proper boost is being reported to the ECU but that it's not making the trip to the cylinders... Why?
    Since it's so simple a job, I'd check the ASV to make sure the plate is in the horizontal position when the engine is running. This can be done with the intake hose off as long as you're in a clean environment and for a short duration. It'll also enable you to assure yourself that there is boost if you feed a bit of fuel.
    On the other side of the coin is fuel. Only if the ECU sees an elevated boost will it dump fuel to the injectors. This is again where the VagCom is necessary. You really need to see what's happening instead of throwing parts at the car.
    My first guess is either a bad ASV or a split in the line somewhere between the turbo and the ASV. My second guess is a plugged intake. It could be before or after the filter. You need to eliminate so you'll be there anyway. Check all the plumbing because I have a feeling your problem is somewhere there.
    cnieto2 likes this.
  4. TDIwtf
    TDIwtf New Member
    Feb 25, 2012
    2006 Jetta TDI BRM
    Hey thanks for the reply.
    Its been getting all the work at a VW / Audi shop. They guy only works on those cars.
    There are no error codes and the the "vagcom" stuff is ok I'm told.
    The car is 5spd manual.
  5. TDIwtf
    TDIwtf New Member
    Feb 25, 2012
    2006 Jetta TDI BRM
    Hey nord
    I actually have 2 Jettas one was written off and was hit from the back. I had the mechanic take the turbo of that one. As that car has tons of power. Driving them was like night and day. Also just as a side note after reading some stuff on here I decided to disconnect the maf sensor and drive it around all day without the hesitation. Then tonight I put it back on to clear the engine light and the problem came back immediately. I will mention this other stuff to the mechanic. Any other thoughts are welcome. Thank you
  6. indigo9585
    indigo9585 New Member
    Mar 21, 2012
    2006 VW Jetta TDI
    2006 VW Jetta TDI
    I'm having the same problem on my 2006 Jetta TDI.
    Did you ever find a solution?
    I've had the EGR valve replaced and the Mass Air Flow.
    I put in a new air filter and the code cleared out.
    After a day the engine light came back on and the hesitation and black smoke are back.
    I checked the new air filter and found soot (not oily) in the air box and the air filter dirty again.
    Switched out the Mass air flow again and the problem still continues.
    Any suggestions would be helpful!
    Thanks.
  7. hevster1
    hevster1 New Member
    Oct 3, 2010
    19
    98 New Beetle TDI
    Alligator tune, PP 357 nozzles, SS 2.5 inch exhaus
    One of the main problems I see with these cars is bringing them to a "VW" shop. These mechanics may know gas engines but not TDI's. Don't keep throwing parts at them. Take them to someone in your area who knows them. If you go to the trusted technicians list on the TDI club forums in the TDI 101 section, you will find someone.
  8. fichfarm
    fichfarm New Member
    Jun 10, 2012
    10
    2006 jetta tdi
    whats an ASV? I am having problems with engine hicups at 2500rpm or so just going down the hiway it will hicup. Manual trans. replaced air, oil and filter, and fuel filter with no change. hicup still there. Also a little hesitant in normal acceleration thru the gears until the turbo kicks in. what do you think?
  9. noairbag
    noairbag New Member
    Jul 12, 2013
    06 jetta tdi
    Im experiencing exactly what user fichfarm mentioned...what turned out to help your problem be resolved
  10. midwestBRM13
    midwestBRM13 New Member
    Sep 12, 2014
    2006 VW Jetta TDI
    Illinois
    Hey guys.... I've had almost exactly the same problems with my 2006 jetta tdi. Black smoke, bogging down in 1st, etc. Did you all ever figure out how to fix it?
    Thanks!!
  11. barsi
    barsi New Member
    Apr 14, 2014
    12
    2004 VW Jetta BEW PD manual ~260000 kms, 2004 VW Jetta BEW PD manual ~350000 kms.
    Whitecourt, Alberta, Canada
    All factory
    I unplugged my mass air sensor and the running problems went away.... check engine light is on though. what is the true fix??
  12. cnieto2
    cnieto2 Member
    Apr 8, 2012
    65
    2003 Jetta TDI ALH 5 Speed, 2006 Jetta TDI BRM DSG, 2001 New Beetle 1.8 T Auto
    Austin, TX. 78760
    I just helped a friend with a 2005 Jetta TDI and the same symptoms.
    Yes, it just stays dead for a moment at the light in first, and then jumps forward spinning the wheels with black smoke.
    The VCDS shows a severe spike in boost pressure, especially in this instance, but also any other time we tried to accelerate.
    After much reading and frustration, we came to the conclusion that it was caused by my friend installing the camshaft for the 2004 BEW engine instead of the original 2005 BRM. The idea being that this cam is more durable.
    Having a less aggressive profile makes it more durable, we read; but then it causes spikes in turbo pressure, low power, and low fuel economy. This we are clearly seeing now. Like someone wrote above; the air is not getting to the cylinders, not immediately.
    He was getting 46-47 MPG at highway speeds of 65-68 MPH, he says; now his display is reporting 38, 39.5 MPG at the most.
    I wanted to adjust the turbo actuating rod to eliminate the spike. He won't allow it. The solution for him now is to drive less aggressive, slowly accelerate every time. Like an old man I say.
    We should be changing his cam to the original on the next timming belt job.
    I guess there could be other restrictions not just the cam in other cases. Or a pressure leak like in my 2003 TDI when a turbo hose was poorly connected, but then I could hear the hissing noise along with the hesitation and black smoke.
    I hope this helps.
  13. vwblah
    vwblah New Member
    Jul 10, 2015
    2006 VW Jetta TDI
    Calgary
    SOLUTION!
    Hi Guys,
    This issue caused me such a headache that I actially signed up just to post this :). There are a couple of things that can cause this and lots of you are close, I checked/replaced most of all of the items mentioned here, lucky I did the work myself so it was not as bad as taking it to shop.
    The solution ended up being the EGR cooler unit. Not the EGR valve itself but the cooler which is a separate part further down attached to the EGR valve. There is a small valve on it that controls the exhaust input back into the engine and it becomes lose and starts a small leak which causes the hesitation in 1st and contributes to the black exhaust smoke.
    Fixed my problem completely.
    Hope this helps.
  14. Hillboy700
    Hillboy700 New Member
    Jul 9, 2015
    06 Jetta tdi
    Eastern Washington
    Does not run
    I have my egr removed and I still have the problem, pulling intake this weekend, checked turbo it was fine cam has wear but not bad going to replace it when money permits
    Where is the best place for full can kit and belt kit
  15. Todd Beay
    Todd Beay New Member
    Jun 15, 2015
    2013 Passat SE TDI
    Brownsville, WI
    I had the same problem with a 2006 Jetta TDI DSG. Put $2000 into it trying to solve it. MAF, All filters, Turbo gaskets and inspection, but the mechanics at the dealer had no clue where to go next. I ended up selling it for a 2013 Passat, I just couldn't justify putting more $$ into it. So Good luck with this! I would be curious to know what it was. I loved that car. :(:(
  16. DePe
    DePe New Member
    Jan 11, 2016
    7
    Volkswagen Jetta 2006
    Chicago
    Kerma TDI Cam and tuning
    I have the same problem will try what vwblah posted to maybe solve it
  17. DePe
    DePe New Member
    Jan 11, 2016
    7
    Chicago
    Is there anyone that knows how to exactly install a new erg cooler unit? Are there any manuals to help with working on your own brm engine? Thanks
  18. David Layman
    David Layman New Member
    May 15, 2017
    2006 VW Jetta TDI
    Bangor, PA
    stock
    I had the same hesitation and black smoke. I finally found a small tear in the intercooler hose from the EGR to the Intercooler. There is an overpriced rubber hose at each end of the tube Part numbers are 3C0145838M for the 90° hose at the ERG end and #3C0145834M for the S shape at the Intercooler end. Do yourself a favor and remove the entire tube before trying to play with the hose clamps.
    The link below is a guy that does a fairly good job of explaining how the EGR and the TDI air intake system works. It led me to find the broken hose that caused my grief.
  19. sktan
    sktan New Member
    Feb 20, 2016
    5
    BMW 2014 X1
    Wenling, Zhejiang, China
    There are lots of videos avaiable out there.
    Just like David Layman, check out his video you may know how to install an EGR cooler, and if you are failed to do that, you may find someone out there to do the job.
