2006 Jetta ECU?
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by spectre, Sep 10, 2017.
  1. spectre
    spectre New Member
    Jan 12, 2015
    27
    vw jetta tdi 2006
    kennesaw ga.
    Where is the ecm located on a 2006 tdi jetta and what has to be removed to get to it.
  2. Keithuk
    7,077
    Why do you want to know, have you got a problem or you want it chipped?
    Its under the skuttle panel where the wipers are. If you google it this there is a good write up how to remove the ECU.
  3. spectre
    spectre New Member
    Jan 12, 2015
    27
    vw jetta tdi 2006
    kennesaw ga.
    Still have problem with the low air flow code the dealer mechanics have said it might be caused by the ecm have changed the maf sensor , egr cooler, cam and lifters,already the code is P0105 they are checking the grounding wires now. I need to know so I can change it myself. Thanks for the info.
