2006 Jetta BEW Clutch problems
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Ahynes94, Aug 26, 2017.
  1. Ahynes94
    Ahynes94 New Member
    Aug 26, 2017
    2006 jetta TDI MKIV
    Newfoundland
    Hey guys!
    Just bought my first TDI, I was told the clutch master cylinder was replaced (checked and confirmed it was) but it wasn't bled after it was installed. I got the car home and bled the system via the slave cylinder, there was a steady shot of fluid coming out, no air or anything. but I still cant put the car in gear if its running (almost like the clutch doesn't disengage), the pedal returns just fine (doesn't get stuck to the ground), I took the slave out and checked for leaks, but it seems to be dry. Is there anything else I can check/try before I go and order a new clutch kit for the car?
