2005 Golf TDI immobilizer delete question
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by SarTech, Aug 26, 2017.
  1. SarTech
    SarTech New Member
    May 27, 2011
    11
    2001 Jetta TDI and 2005 Golf TDI
    Canada
    Recently bought a 2005 Golf and have lost the spare keys... I'm trying to determine if a immobilizer delete has already been done to the ECU.
    The key it came with is missing the VW emblem which may mean that it was a non dealership key. I realize I could have a key made without matching the SKU and see if it works.
    Is there a way to determine this using a VCDS?
    Thanks a bunch
  2. Keithuk
    7,131
    You can have a key made but you need the Secret Key Code (SKC) not SKU. VCDS won't find the SKC only VAG-Tacho will. VCDS will once you have the SKC.
    The immobilizer can only be deleted if you contact a chip tuner.
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,821
    Scotland
    PP764's, turbo and mapping
    Usually if the immo has been deleted the immo light flashes all the time.
  4. SarTech
    SarTech New Member
    May 27, 2011
    11
    Canada
    I understand the SKC and how the VCDS cannot retrieve the SKC. I was wondering if the VCDS can confirm if the immobilizer is active or has been removed.
  5. Keithuk
    7,131
    VCDS can look at Address 25: Immobilizer (J334).
