2004-2006 mk4 FAQ list and "how to" index for pumpe duse TDI
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by chittychittybangbang, Aug 26, 2007.
Thread Status:
Not open for further replies.
  1. chittychittybangbang
    23,804
    Volkswagen MK4 turbodiesel "how to" index
    For 2004-2005 Jetta TDI and 2004-2006 New beetle and Golf
    updated Sept 15, 2013
    This page is for mk4 Jetta, Golf, and New Beetle TDI 2004-2006. In 2005.5 the Jetta became a mk5 so see 1000q: mk5 Jetta DIY index if you're looking for the newer body style. In North America, the mk4 pumpe duse use the "BEW" TDI engine. 2003 and earlier 4th generation cars are not pumpe duse and use the "ALH" TDI engine. Review the main index page if that's what you have. Here are some more checks to see if you have a pumpe duse or not 1000q: cosmetic differences on Jetta and 1000q: injection pump vs. PD vs. common rail. If you have a 2004-2005 Passat, see 1000q: B5 Passat "how to" index.
    Did you just buy this car or are you looking to buy one? If so, see 1000q: mk4 TDI new car checklist to see a list of common service /problem areas, catch-up maintenance, and VW quirks.
    Engine
    Post glow plug recall hard or no starting in cold temperatures
    BEW engine timing belt part 1 removal (pumpe duse engine) Inspect at 80,000 and replace no later than 100,000 miles
    BEW engine timing belt part 2 installation (pumpe duse engine) (exclusive content, please join our community for free to view)
    TDI EGR valve FAQ (exhaust gas recirculation valve)
    How to inspect the PD TDI engine camshaft lobes for wear on the pumpe duse engine
    How to remove PD TDI fuel injectors (please join our forums to view)
    How to remove PD TDI fuel inj #2
    How to fix a hard engine start or rough idle caused by camshaft timing
    Water pump replacement (recommended with every timing belt change)
    Thermostat replacement (check your coolant temp sensor first)
    Radiator removal
    Engine oil change for TDI engine (10,000 miles or as needed)
    Engine oil pan replacement
    Front crankshaft seal replacement
    Engine coolant and antifreeze flush (100,000 miles or as needed)
    Radiator replacement
    How to change the air filter or interior cabin air filter
    Intake manifold removal and replacement
    Fuel filter change (20,000 miles change interval - important) (anti theft system)
    Comparison between older systems, pumpe duse, and common rail direct diesel fuel injection
    Starter system troubleshooting and replacement
    Alternator, AC compressor, and Power Steering Pump removal
    Alternator troubleshooting, pulley replacement, and voltage regulator repair
    Battery part number reference
    How to replace the AC coil
    Tightening the AC compressor nut (this nut can come loose and cause damage)
    MAF technical info (mass air flow sensor FAQ and part numbers)
    MAF (mass air flow sensor) troubleshooting and replacement procedures
    Immobilizer general information ,troubleshooting, procedures (anti theft system)
    Keyless entry FAQ and how to program new VW keys and remote fobs
    Engine runaway FAQ (rare problem where the engine races on its own due to mechanical malfunction)
    Diagnosing and fixing limp mode (sudden loss of power)
    Diagnosing and fixing low power
    (constant low power and can't rev high)
    How to do a boost or vacuum leak check on your turbo VW (can cause a hissing noise or more than normal black exhaust)
    Variable vane turbo (VNT) actuator removal or adjustment (not regular maintenance or tuning item)
    modified VNT actuator installation for smart sensor actuators
    VNT turbo vane cleaning (to free stuck vanes)
    How to remove the turbo on Jetta, Golf, or New Beetle (on earlier engine but it includes some BEW engine specific notes)
    ALH engine TDI turbo removal
    (pumpe duse engine similar, mirrored link from TDIinnovations of TX)
    Turbo performance upgrade guide for TDI (comparison chart)
    Fuel tank vent FAQ and removing the vent internals (this lets you add a few more gallons of fuel per tank)
    Fuel door spring open modification (this lets the door open much farther when you press the button)
    Metal skid plate installation (this protects the exposed oil pan, also includes a comparison of skidplates)
    Stripped glow plug thread repair
    How to repair broken plastic vacuum nipple
    How to replace the glow plug on TDI
    Drivetrain
    Clutch/brake fluid change
    Manual transmission gear oil change
    TDI clutch and flywheel FAQ
    DSG transmission FAQ
    Manual transmission removal (for earlier ALH engine but BEW should be similar)
    (external link)
    How to adjust the VW shifter cables
    DSG fluid change (only the New Beetle has this, shown on mk5)
    Dieselgeek short shifter installation and review (mk5 shown but mk4 is similar)
    Wheel / tire / gearing calculator
    Wheel tire calculator - also shows wheel/tire clearance, offset, and final drive calculator
    Brakes/Suspension
    Front and rear brake pad and rotor job
    Rear wheel bearing replacement
    Brake fluid and clutch fluid service
    Parking brake cable service and adjustment
    Strut, spring, and mount replacement first writeup
    Strut, spring, and mount replacement second writeup
    Sway bar bushing and endlink installation
    LCA, ball joint, and bushing replacement
    Dogbone/pendulum mount replacement
    Brake tips and busting big brake myths
    TDI specific big brake upgrade FAQ and spec table/links
    Installing larger brake carriers (must have 1.8T/VR6 or other spindle to use)
    Audi TT/VW golf R32 spindle and /or lower control arm conversion (also lets you use larger brakes)
    DIY pressure brake/clutch bleeder
    Brake booster removal and replacement
    Steering wheel removal on Jetta and Golf (New Beetle similar)
    Steering rack replacement (external youtube video - CAUTION, do not support your car using cinder blocks as shown in the video, it's a 3rd party video!)
    Car Detailing
    Car detailing index: wash and wax the proper way, polishing paint, using rubbing compound, clay bar treatment
    Washing/waxing your car - yes, there is a right way
    Polishing your paint/swirl mark removal - enhance paint shine and remove paint spiderwebbing
    Clay bar treatment - make the paint feel like glass
    Sticker removal - safely remove that sticker from the paint
    Headlight polishing - restore the headlight plastic to clear
    Wax stain removal - remove white stains on the trim
    Paint chip repair
    Small scratch removal
    General/miscellaneous
    VCDS (ross tech vagcom) mods, tricks, and settings - These can disable auto-unlock of the doors above 10 mph, unlock all doors with one press of the remote, or adjust the horn/light blinking when locking/unlocking the car.
    How to use a torque wrench, buyer's guide, and FAQ
    How to fix a fast speedometer
    Tips and tricks for the mechanic
    What the VW part numbers mean and how to view them in ETKA numbering system
    How to compression test the engine
    Making wood blocks to raise the car
    OEM wheel gallery and specs
    Exterior/interior
    Jack points on my VW Jetta TDI
    Adding soundproofing to your car and introduction to soundproofing theory
    Rust on the front fenders above the wheels? See this TSB
    5th gear modification to lower the rpm
    -5th gear install by Audi5jim
    Aspheric (blind spot), convex, and flat - mirror replacement and repair FAQ
    Instrument cluster removal and high beam indicator dimmer
    Ecode headlights - what are they and how do you use them
    Rear bumper and taillight removal
    Broken intercooler mounting stud repair
    Clearing the sunroof drains to prevent water in the interior (or repairing the broken drain line)
    Center console removal
    How to add an OEM iPod cable to your car and compatibility
    Dashboard camera (dashcam) hardwire installation
    Vinyl shifter boot replacement with leather
    DIY repair of a clicking turn signal relay and replacement of the hazard switch (or turn signals not working)
    How to replace the ignition key cylinder or switch
    How to remove and change the headlight bulbs
    Disable drl (daytime running lights)
    Window regulator - making creaking or popping sounds (the window glass can fall into the door and leave the window open)
    Door card (the interior panel) removal
    New Beetle broken door handle repair
    Door lock module removal
    How to remove the side marker light
    Mudflap installation
    How to remove the front bumper or remove the headlight hosuings
    Rear shelf removal
    Fender rolling
    Repainting the triangular trim on the rear window that likes to rust
    Glove box repair
    Glove box lock cylinder replacement
    where is it: the location of random stuff that is useful to know.
    MK3 vs MK4 differences - 3rd vs. 4th generation differences
    MK4 vs MK5 differences - 4th vs. 5th gen differences
    light bulb replacement reference table
    Wheel alignment specifications table
    Touch up paint code reference table
    To add heated seats, you need a retrofit harness, heated seats, and the heated seat buttons.
    Power seat / heated seat retrofit
    How to add a fuse or new circuit to the fusebox
    More How tos and general TDI FAQ at 1000 answered questions: index
Thread Status:
