1998 Jetta TDI: Pop, then coolant leak
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Combobulator, Oct 4, 2016.
  1. Combobulator
    Combobulator New Member
    Oct 4, 2016
    4
    VW, Jetta TDI, 1998
    Florida
    My 1998 Jetta TDI has some AC problem. The fan wasn't going while the car wasn't moving but I had the AC on and I heard a loud pop. White smoke came from the passenger side of the hood, I pulled over and saw a lot of antifreeze in that section of the engine bay and what might be a sensor dangling that used to be connected to a cylinder that connects to the radiator and something else above it. It's in front of the passenger front side wheel, just behind the front bumper. I don't know if it's an urgent fix or not. I have no idea what that unit is and haven't been able to find it after numerous searches. Maybe since Jetta diagrams don't seem to include it, I can just pinch it off and keep driving. ;)
    I drove it back home and there was no more smoke and it hasn't continued to drip on my driveway. My coolant levels are ok. Pic of the unit from the bottom included. The tube gonig to the bottom of the image goes to the radiator.
    [​IMG]
  2. Magnus
    Magnus Member
    Apr 6, 2015
    58
    VW T4 AXL 2.5Tdi Syncro 2002
    Örnsköldsvik
    Airsuspension.
    That is the pressure sensor for your air condition.
    You need a new sensor and to do vacuum and fill up your a/c again but first fix your radiator fans.
    The white smoke was refrigerant escape out from your system and what looks like coolant is oil probably.
    So you must also fill oil in your air condition to not harm your compressor.
    Wish you luck and take to a shop that know what they do with air condition units.
    Most important now fix your fans.
    Skickat från min iPhone med Tapatalk
    Combobulator likes this.
  3. Combobulator
    Oct 4, 2016
    4
    VW, Jetta TDI, 1998
    Florida
    Thanks for the information. Is it ok to drive for now as long as I leave the AC off?
  4. Magnus
    Magnus Member
    Apr 6, 2015
    58
    Örnsköldsvik
    Airsuspension.
    Yes but keep an eye on your temp gauge.
    Never leave the engine running and go and do something else.
    If it gets to hot it can be damaged.
    Sorry for my late answer.
  5. Combobulator
    Oct 4, 2016
    4
    VW, Jetta TDI, 1998
    Florida
    Np. I put a bag over the sensor and where it plugs into. Not a lot of fluid has leaked out since. The temperature has been OK so far. Thanks for the info.
  6. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,404
    85 kubvan
    its a gas.. not fluid...
  7. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Under pressure it turn to liquid.
    Magnus likes this.
