09 Jetta won't start after pump replaced
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by dieselherb1, Dec 28, 2016.
  1. dieselherb1
    dieselherb1 Member
    Nov 10, 2010
    52
    96,2 97Passats,98,2000 Jettas,3 81 Rabbit pickups, 95 Chevy pickup diesel
    I'm selling the 09 Jetta back to VW. I had a CP3 pump on the engine so I put the original pump back on, now won't start. Can't check for codes something happened to my VCRs cable. Have fuel at pump and at injectors. Both cam sprocket and pump sprocket bolts in middle of slot. Is timing that critical on this pump, CP3 pump was easy. Need help Thanks
    23,889
    No, it just has to be rough with the pin since the fuel rail handles the timing of fuel injection. Perhaps pressure is low? See if you can get codes since that may save a lot of time.
  3. dieselherb1
    dieselherb1 Member
    Nov 10, 2010
    52
    Two codes 008448 008449
  4. dieselherb1
    dieselherb1 Member
    Nov 10, 2010
    52
    Would pump pressure show in vcds when cranking engine?
  5. dieselherb1
    dieselherb1 Member
    Nov 10, 2010
    52
    Got it started. Andrew steered me in the right direction. It was dirt or crap under the bypass valve. I took the easy way out replaced the pump head.
  6. Keithuk
    6,912
    VAG Error Code: 18532/5290/008448
    EOBD II Error Code: P2100
    Fault Location:
    Throttle Actuator Control System - Open Circuit
    Possible Cause:
    Fuse(s).
    Wiring/Connector(s).
    Throttle actuator control motor.
    Throttle actuator control motor relay.
    Possible Solutions:
    Check/Replace Fuse(s).
    When is the code detected?:
    Power supply for the throttle control motor is provided to the Engine Control Module (ECM) via throttle control motor relay. The throttle control motor relay is ON/OFF controlled by the Engine Control Module (ECM). When the ignition switch is turned ON, the Engine Control Module (ECM) sends an ON signal to throttle control motor relay and battery voltage is provided to the Engine Control Module (ECM). When the ignition switch is turned OFF, the Engine Control Module (ECM) sends an OFF signal to throttle control motor relay and battery voltage is not provided to the Engine Control Module (ECM).
    VAG Error Code: 18533/008449
    EOBD II Error Code: P2101
    Fault Location:
    Throttle Actuator Control System - Range/Performance Problem/Malfunction
    Possible Cause:
    Possible Solutions:
    AS taken from my new Free EOBD II Error Codes software
