09 CR manual into 06 PD DSG
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by dieselherb1, Nov 18, 2017.
  1. dieselherb1
    dieselherb1 Member
    Nov 10, 2010
    58
    96,2 97Passats,98,2000 Jettas,3 81 Rabbit pickups, 95 Chevy pickup diesel
    Ok got the engine running but have 2 codes and limp mode. Codes p0101 and p0238. Engine has CP3 pump, 20/60 turbo and Malone stage 3 tune. I do not know what the MAP sensor is but glow plug lite is flashing. Any thoughts? Thanks!
  2. Keithuk
    7,170
    VAG Error Code: 16485/000257/4794/5667
    EOBD II Error Code: P0101
    Fault Location:
    Mass Air Flow (MAF) Sensor (G70) - Circuit Range/Performance Problem/Implausible Signal
    Possible Cause:
    Loss of Power.
    Erratic Idle.
    Wiring/Connector(s).
    Air Leak(s) after Mass Air Flow (MAF) Sensor (G70).
    Excessive restrictions in the Intake/Exhaust System.
    Dirty air filter, clogged snow screen, clogged CAT.
    Mass Air Flow (MAF) Sensor (G70) faulty,
    Ground Spots corroded or Paint Residue.
    Possible Solutions:
    Check Intake Air Filter.
    Check Mass Air Flow (MAF) Sensor (G70).
    Check Earth Points.
    Mass air flow vs upper threshold model < 60 - 800 kg/h.
    Lower threshold model < 0 - 400 kg/h.
    Load calculation > 18%.
    Fuel system < -17%.
    Special Notes:
    In MY 1995-2002 (?) in Europe at VW diesel cars Mass Air Flow (MAF) Sensor (G70) had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [Measuring Value Blocks (MVB) - 08], group 003 (3e gear, full throttle, from 1700-4000rpm).
    It is not uncommon for a TDI to set Implausible Signal Mass Air Flow Sensor (G70) faults when the engine performance is reduced due to a mechanical problem. These mechanical problems may include, but are not limited to:
    Faulty electric fuel pump or Restricted fuel filter. See the Fuel Pump Basic Settings for PD, PPD, and CR TDI Engines page for Basic Settings tips after replacement.
    Excessive restrictions in the intake/exhaust system.
    Internal camshaft/valve/lifter problems.
    Tech Notes:
    Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    When is the code detected?:
    A high voltage from the sensor is sent to Engine Control Module (ECM) under light load driving condition.
    A low voltage from the sensor is sent to Engine Control Module (ECM).
    Description:
    The Mass Air Flow (MAF) Sensor (G70) is placed in the stream of intake air. It measures the intake flow rate by measuring a part of the entire intake flow. It consists of a hot film that is supplied with electric current from the Engine Control Module (ECM).
    The temperature of the hot film is controlled by the Engine Control Module (ECM) a certain amount. The heat generated by the hot film is reduced as the intake air flows around it. The more air, the greater the heat loss. Therefore, the Engine Control Module (ECM) must supply more electric current to maintain the temperature of the hot film as air flow increases. The Engine Control Module (ECM) detects the air flow by means of this current change.
    VAG Error Code: 16622/15984/000568/4166/5169/7295
    EOBD II Error Code: P0238
    Fault Location:
    Manifold Pressure/Boost Sensor (G31) - Signal too High
    Possible Cause:
    Manifold Pressure/Boost Sensor (G31) faulty.
    Possible Solutions:
    Check Manifold Pressure/Boost Sensor (G31).
    Signal voltage > 4.88 V.
  3. dieselherb1
    dieselherb1 Member
    Nov 10, 2010
    58
    I checked the wiring from the MAF and MAP to ECU, good continuity. Tried another MAF, same.
