06' jetta tdi with ac problems.
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by gassprint1, Sep 1, 2017.
  1. gassprint1
    gassprint1 New Member
    Aug 11, 2017
    Knox, IN
    no mods
    so i got my vcds and ran a scan. lots came up. my focus was the ac system. i ran the tests and everything came out ok so it said. i ran the values screens also.
    Friday,01,September,2017,12:36:31:00350
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
    VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
    Data version: 20170721 DS276.2
    www.Ross-Tech.com
    VIN: 3VWCT81K06M852015 License Plate:
    Mileage: 227272 Repair Order: 1
    Address 08: Auto HVAC (1K0 820 047 GS)
    12:34:29 Group 001
    0.0 Compressor Shut-Off Code
    800 /min Engine Speed
    0.0 km/h Vehicle Speed
    04:00 Standing Time
    12:34:29 Group 002
    Compressor Current (actual)
    0.820 A Compressor Current (specified)
    1000 /min Compressor Speed
    1.2 Nm Compressor Load
    12:34:29 Group 003
    4.8 bar Refrigerant Pressure
    10.0 % Radiator Fan Activation (actual)
    0.0 % Radiator Fan Activation (spec.)
    OFF Engine Speed Increase
    pressure is low. i waited with engine off for a bit and did it again. pressure read 5.8-6.0 bar. makes no sense to me. i was told to clear everything out and run a scan again. the hvac didn't show up the second scan. i was told it was the compressor..bad. last weekend i replace the solenoid valve in the compressor as it was stated most all the time the valve was the problem. didn't work for me. fans are fine but won't kick on when i hit the ac button.
    first scan below...
    Friday,01,September,2017,12:11:30:00350
    www.Ross-Tech.com
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
    72 7D
    VIN: 3VWCT81K06M852015 Mileage: 365760km-227272miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Sporadic communication error 1000
    08-Auto HVAC -- Status: Malfunction 0010
    0F-Digital Radio -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    1C-Position Sensing -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    65-Tire Pressure -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 038-906-016-BEW.lbl
    Part No SW: 03G 906 016 AC HW: 028 101 223 9
    Component: R4 1,9L EDC G000DG 7551
    Revision: --H06--- Serial number: VWZ7Z0F9020406
    Coding: 0050078
    Shop #: WSC 00066 000 00000
    VCID: 6492A451A25BAAC7DF2-8030
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 042 H HW: 02E 927 770 AD
    Component: GSG DSG 070 0913
    Revision: 04507000 Serial number: 00000506030042
    Coding: 0000020
    VCID: 186AC0A12E93BE2783A-804C
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0021122
    VCID: 73B0D70D17B53D7F568-8026
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 GS
    Component: Climatic PQ35 120 0606
    Shop #: WSC 00000 000 00000
    VCID: 7BA0FF2D3FE5753F0E8-802E
    1 Fault Found:
    00898 - Control Circuit A/C compressor
    010 - Open or Short to Plus - Intermittent
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
    Component: Bordnetz-SG H46 1501
    Revision: 00H46000 Serial number: 00000000499975
    Coding: 14018E234004150007140000001400000028770B5C0000
    VCID: 3728231D434D915FAA0-8062
    Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 021206 020 0501
    Coding: 00065535
    Shop #: WSC 00066
    4 Faults Found:
    01504 - Bulb for License-Plate Light (X)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 20
    Mileage: 365674 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 12.80 V
    ON
    ON
    OFF
    OFF
    ON
    02092 - Enabling Heated Seat
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 237
    Mileage: 364077 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 12.20 V
    ON
    ON
    OFF
    OFF
    OFF
    01333 - Door Control Module; Rear Left (J388)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Mileage: 365164 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.40 V
    OFF
    ON
    OFF
    OFF
    OFF
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 244
    Mileage: 364057 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 12.55 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
    Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
    Component: SDAR SIRIUS H03 0060
    Revision: 00000000 Serial number: AUZ4Z7F0016432
    VCID: 2A0E0A6980FF3CB725E-807E
    2 Faults Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 205
    Mileage: 364077 km
    Time Indication: 0
    02788 - Internal Communications Error
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 157
    Reset counter: 22
    Mileage: 364077 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:10
    Freeze Frame:
    Bin. Bits: 00000000
    Bin. Bits: 00000001
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
    Component: 69 AIRBAG VW8R 034 8000
    Revision: 05034000 Serial number: 003B6D074102
    Coding: 0013881
    VCID: 6C82CC714A8BE287972-8038
    Subsystem 1 - Part No: 1K0 959 339 F
    Component: BF-Gewichtsens. 007 0005
    Subsystem 2 - Serial number: 6332MSME12416057/
    Subsystem 3 - Serial number: 6342MSME1345307B6
    Subsystem 4 - Serial number: 6351HSME0B3C0A519
    Subsystem 5 - Serial number: 6361HSME0B3C1577E
    Subsystem 6 - Serial number: 63727SME0B2F1F1FK
    Subsystem 7 - Serial number: 63827SME0B2F527FI
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
    Component: J0527 036 0070
    Coding: 0012021
    VCID: 035087CD47150DFF468-8056
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
    Component: KOMBIINSTRUMENT 3HL 1610
    Revision: V0003000 Serial number: VWZ7Z0F9020406
    Coding: 0023203
    Shop #: WSC 08207 444 84795
    VCID: 2E060679BC175097F96-807A
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 244
    Mileage: 364057 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 10:31:43
    Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 H HW: 1K0 907 951
    Component: J533__Gateway H12 0150
    Revision: H12 Serial number: 3100106A090654
    Coding: 3FBF0B620F001002
    VCID: 2C020C718A0B2287D72-8078
    3 Faults Found:
    00484 - Vehicle Position Recognition Control Module (J603)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 28
    Mileage: 354855 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:36:14
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 244
    Mileage: 364057 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 10:31:44
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 13
    Mileage: 365164 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 13:02:20
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
    Component: Kompass 005 0003
    Revision: 00005000 Serial number: 1293324T2C5703
    Coding: 0000003
    VCID: 392C25257559872F5C4-806C
    1 Fault Found:
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 364077 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:06:57
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO 3HL 1610
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1127
    Revision: 32008001 Serial number: 00000557469105
    Coding: 0001205
    VCID: 3B203F2D7F65B53F4E8-806E
    3 Faults Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Freeze Frame:
    Fault Status: 00100101
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 9
    Mileage: 0 km
    Time Indication: 0
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00111000
    Fault Priority: 3
    Fault Frequency: 96
    Reset counter: 7
    Mileage: 354531 km
    Time Indication: 0
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 15
    Reset counter: 21
    Mileage: 362708 km
    Time Indication: 0
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.070 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 34321411523B7A478F2-8060
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
    Component: KSG PQ35 RDK 051 0215
    Revision: 00051000 Serial number: 00000000000000
    Coding: 13900F880186281B0904058FB0880F0488DC00
    VCID: 74B2D41112BB3A474F2-8020
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 47: Sound System Labels: 3C0-035-456.clb
    Part No: 1K6 035 456 A
    Component: 08K Audioverst. 0005
    Revision: 00003000 Serial number: 00000000019550
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1127
    Revision: 32008001 Serial number: 00000020969109
    Coding: 0001204
    VCID: 3C223C317A6BB207472-8068
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
    Component: Radio DE2 145 0176
    Revision: 00145000 Serial number: VWZ4Z7F2133958
    Coding: 0010400
    VCID: 2412E451E2DBEAC71F2-8070
    5 Faults Found:
    00870 - Bass Speaker Front Left (R21)
    011 - Open Circuit
    00871 - Bass Speaker Front Right (R23)
    011 - Open Circuit
    00872 - Bass Speaker Rear Left (R15)
    011 - Open Circuit
    00873 - Bass Speaker Rear Right (R17)
    011 - Open Circuit
    00003 - Control Module
    014 - Defective
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
    Component: J388 TUER-SG HL 1115
    Revision: 12005001 Serial number: 00000000759245
    Coding: 0001168
    VCID: 3E2636396C77A017696-806A
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0420
    Coding: 0100101
    1 Fault Found:
    00625 - Vehicle Speed Signal
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 364077 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:06:58
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
    Component: J389 TUER-SG HR 1115
    Revision: 12005001 Serial number: 00000000769484
    Coding: 0001168
    VCID: 3FD84B3D6B7DA91F620-806A
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D040175B1112B8FC0C-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End----(Elapsed Time: 01:36, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
