06 Jetta BRM VNT adjustment
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by StormyWardik, Jun 18, 2016.
  1. StormyWardik
    StormyWardik Member
    Mar 17, 2016
    32
    Clarksville, TN
    So I've been just driving the jetta around without adjusting the VNT at all for about 500 miles after rebuilding the turbo... I dont have the vag com thingy ... Does anyone know about how much the VNT is supposed to be adjusted? It starts to sound like it's spooling at around 2k RPM while im at around 70MPH... doesn't sound right.. then push the pedal a little and then a little more power and the spooling sound stops... I'm just being lazy...
    gtihodi likes this.
    23,902
    That is too high. Do you at least have a vac pump w/gauge? That will show you ballpark, DIY is in the FAQ
    gtihodi likes this.
  3. StormyWardik
    StormyWardik Member
    Mar 17, 2016
    32
    Clarksville, TN
    Yeah I was going to adjust it to open up more in the morning. Still don't know if everyone means lengthen/shorten is about the excess rod or not.
    Sent from my SM-G900V using Tapatalk
  4. StormyWardik
    StormyWardik Member
    Mar 17, 2016
    32
    Clarksville, TN
    I adjusted it the way the DIY said and hits the stop at 18hg..but then I'd have to have the vanes closed more.. herm...
  5. gtihodi
    gtihodi New Member
    Dec 25, 2014
    11
    06 jetta tdi
    knoxville ,tn
    removed egr cooler
    Any ideas about. Adjustment of actuator?my kicks out often and can't find the sweet spot. I made a wrench by slicing a slot and shortening an ignition wrench
