01259 - Fuel Pump Relay (J17) MK5 GT TDI golf
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by ak77, May 10, 2015.
  1. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hi Guys, can someone please help me. I need to locate the Fuel Pump Relay (J17) on an MK5 GT TDI golf .
    The car has a problem starting, it sounds like the fuel is not flowing to the engine dough I can hear the pumps noise.
    It takes second turn of the key to start up with the foot on the accelerator.
    I got the error code on the VCDS:
    Please any ideas where/what I should be looking at?
    Many thanks in advance.
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007980938
    Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
    Shop #: WSC 00046 412 00000
    VCID: 71E9E6E4680A31A9911-8024
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 140707 020 0501
    Coding: 00049109
    Shop #: WSC 00046
    Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
    Component: RLS 310806 020 0105
    Coding: 00208933
    Shop #: WSC 00046
    2 Faults Found:
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 106198 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.15 V
    ON
    ON
    OFF
    OFF
    OFF
    02092 - Enabling Heated Seat
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 106198 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.15 V
    ON
    ON
    OFF
    OFF
    OFF
  2. Keithuk
    7,079
    Well if you can hear the fuel pump buzzing then its running. I would check for other problems like fuel lines and when was the fuel filter last changed?
    http://workshop-manuals.com/audi/a2.../testing_fuel_pump_relay_-j17_and_activation/
    There are two fuel pump relays called J17 (449 on top) at position 2/2 under the dash which supplies the fuel pressurisation pump in the tank and Fuel Pump 2 Relay (J49) (449 on top) at position 1/1 under the dash which is Fuel Pump 2 Relay (J49) and supplies fuel pump 2 in the engine bay. Both relays are part number 1K0 951 253 and cost about £11 from a VW dealer.
    VAG Error Code: 01259
    Fault Location:
    Fuel Pump Relay (J17) - Open Circuit/Short Circuit to Earth - Intermittent
    Possible Cause:
    Misfiring.
    Engine cuts out.
    Fuse(s).
    Wiring/Connector(s) from/to Fuel Pump Relay (J17) faulty.
    Possible Solutions:
    Check/Replace Fuse(s).
    Check/Replace Wiring/Connector(s) from/to Fuel Pump Relay (J17).
    Check Fuel Pump Relay (J17).
    VAG Error Code: 02092
    Fault Location:
    Enabling Heated Seat - Open Circuit/Short Circuit to Earth
    Possible Cause:
    Seat Heating not working.
    Fuse(s).
    Wiring/Connector(s) from/to Central Electronics Control Module (CECM) (J519) from/to Seat Heating Control Module faulty.
    Control Module incorrectly coded.
    Possible Solutions:
    Check/Replace Wiring/Connector(s) from/to Central Electronics Control Module (CECM) (J519) from/to Seat Heating Control Module.
    Check Control Module Coding.
  3. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hey, thanks for that, I will check,
    Where is the fuel filter on GT golf?
    I got a feel it's an electrical prob.
    Cheers for helping .
    Do you have the part nuber for the relays responsible ?
  4. Keithuk
    7,079
    I did a quick search in ETKA last night but I couldn't find it. If you google it Mk5 Golf GT TDI fuel pump relay.
    If you can locate it and pull it out there should be a part number on it. Post it or type it in or copy and paste into http://www.partsbase.org/vw/
    The fuel filter will be on the left hand side as you lift the bonnet. There is an article on changing the fuel filter in TDI Wiki if you search.
  5. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    This really came in handy
  6. Keithuk
    7,079
    google it further.
    The Mk5 covers many year what's yours and the engine code?
    http://www.autogenius.info/en/volkswagen-golf-5-fuse-box-diagram/
    This one only shows 1.4 and 1.6 which is different from what's shown in AD as that shows it No.2 in the Facia2 relay box.
    On a 2005-06 Golf 1.9 TDI-PD, BJB. That's the same on a 2004-08 Golf 2.0 SDI.
    409 appears to be the relay number.
  7. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    2007 BMN engine .
    I think its 460 ? Not sure
  8. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    P.s what software are you using to see thus?
  9. Keithuk
    7,079
    The BMN is a 125PS 2.0 TDI-PD use in 8 VAG models, in the Golf 11/05-11/08.
    Yes is the same picture for the BMN.
    I use AD for a lot of info.
    The 460 relay is X-Contact Relief Relay (J59).
  10. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Is this the technical VW term "X-Contact Relief Relay" or do they call it something else. I tried searching but could not find. Eteka & Elsa. ps What is AD?
  11. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hey, I'm looking at this diagram and my control module with relays looks different to this.
    I have two 460 relays under the steering on drivers side and both I have tested and work fine. Ive looked at the connection under the rear seat at the tank side and all is fine.
    I'm confused about 3d Lighting interior and Seat Heated error, ( no heated seats)?
    Any help , please ? It very much appreciated.
    ______
    Thursday,25,February,2016,18:30:22:41771
    VCDS Version Release 15.7.3 Running on Windows XP x86(VMWare)
    www.Ross-Tech.com
    Control Module Part Number: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component and/or Version: Bordnetz-SG H54 2202
    Software Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
    Work Shop Code: WSC 00046 412 00000
    Additional Info: 1K2955119E Wischer 140707 020 0501 1K0955559AB RLS 310806 020 0105
    VCID: 71E9E6E4680A31B68E-8025
    Fault Codes have been Erased
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    00059 - Terminal 30 for Interior Lighting
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
  12. Keithuk
    7,079
    AD is a abbreviation for AutoData.
    http://www.volkswagenforum.co.uk/showthread.php?t=4377
    VAG Error Code: 00059
    Fault Location:
    Terminal 30 for Interior Lighting - Electrical Fault in Circuit/Open Circuit
    Possible Cause:
    Interior Light not working.
    Fuse(s).
    Wiring/Connector(s).
    Possible Solutions:
    Special Notes:
    When found in VW Golf (1K) or similar:
    Check Fuse(s) in Dash Board and Electronic Box (Engine Compartment)
    Check bolted Power Connections in Electronic Box (Engine Compartment)
    Check/Replace Wiring/Connector(s) from/to Central Electronics Control Module (CECM) (J519).
    Check Power Supply Relays for Terminal 30 (J317)
  13. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hey, do you know if those 3 errors would be related , as I don't heated seats in my GT/ and all interior lights work :)
  14. Keithuk
    7,079
    That's one of the codes you've shown?
  15. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hey Keith, I know that's why I'm confused. Do you know what fuse would I be looking at responsible for interior lights?
    Cheers bud, your help so far is greatly appreciated.
    Al
  16. Keithuk
    7,079
    I can't see anything for interior lights but there is heated seats circuit breaker on the same picture I've post F4 top right.
  17. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hi guys, just wondering if anyone can offer some assistance here. I have had this GTd golf now for 2 years and it seems cursed with electrical issues.
    Everything from injector failure to interior lighting. I have ironed out much of it but yesterday the car stopped and wont turn on.
    Last thing fixed on the car was the G28 sensor ( replaced 2 months ago. ). this seems to be persistent error together with fuel pump relay error.
    Now I have below errors and as car is a non mover. Any help would be appreciated as this car has now cost me a small fortune.
    _______________________________________________________________________________________
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ8U002011 Mileage: 125670km-78087miles
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 FC HW: 03G 906 018 FC
    Component: R4 2.0l PPD1.2 G 1155
    Revision: --H42--- Serial number: VWX7Z0G43NO1FZ
    Coding: 0000078
    VCID: 6BD5F48C4A26DB66B4-803F
    1 Fault Found:
    000801 - Engine Speed Sensor (G28)
    P0321 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 125679 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:25:49
    Freeze Frame:
    RPM: 128 /min
    Torque: 96.0 Nm
    Speed: 0.0 km/h
    Time: 0.01 s
    Angle: 0.0 ∞
    Bin. Bits: 00000000
    Bin. Bits: 00000001
    Readiness: N/A
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    Part No SW: 02E 300 044 L HW: 02E 927 770 AE
    Component: GSG DSG 081 1403
    Revision: 04608010 Serial number: 00000704301340
    Coding: 0000020
    Shop #: WSC 44551 111 44551
    VCID: 1E33ED58C914FECE63-804B
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    VCID: 73E5ECEC121603A67C-8027
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
    Component: ClimatronicPQ35 120 1111
    Revision: 00120021 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 78FFDBC00B7060FE49-802D
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    000 - - - Intermittent
    Coding: 00049109
    Shop #: WSC 00046
    Coding: 00208933
    Shop #: WSC 00046
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Status: 01111001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    02399 - Control Circuit for Terminal 30 for Interior Illumination
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.45 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 111
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 1P AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD19R1ST
    Coding: 0012624
    VCID: 3D710AD464D285D65A-8069
    Subsystem 1 - Serial number: 6332MSME173C6109A
    Subsystem 2 - Serial number: 6342MSME1A251E29G
    Subsystem 3 - Serial number: 6352QSME265C3269M
    Subsystem 4 - Serial number: 6362QSME274E403BN
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
    Component: J0527 636 0070
    Coding: 0012122
    VCID: 0109B62458AA21367E-8055
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 874 B HW: 1K0 920 874 B
    Component: KOMBIINSTRUMENT VDD 1216
    Revision: V0002000 Serial number: VWX7Z0G43NO1FZ
    Coding: 0003103
    VCID: 2C5737908FA81C5EFD-8079
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533 Gateway H07 0052
    Revision: H07 01 Serial number: 040607F2001151
    Coding: ED807F0E0002020003
    VCID: 306F23E0A38078BEC1-8065
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1216
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
    Component: Tuer-SG 006 120B
    Coding: 0000692
    VCID: 39791EC470FAB9F676-806D
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.069 H08 1901
    VCID: 366315F841E4568E9B-8063
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 809002005103087F2D0484056008DF0380FC00
    VCID: 0305BC2C42B633266C-8057
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
    Component: Tuer-SG 005 090B
    Coding: 0000948
    VCID: 3A7B01C875FCB2EE7F-806F
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 56D 035 190 A HW: 56D 035 190 A
    Component: RCD510USBRVC 001 0003
    Revision: -----001 Serial number: VWZ4Z3M8175927
    Coding: 0100046404000B
    Shop #: WSC 00078 790 00230
    VCID: 224BD9A83D6CDA2E47-8077
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 123632 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:42:30
    02873 - Control Module for Back-Up Camera (J772)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:43:11
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 006 1201
    Coding: 0000144
    Shop #: WSC 00046 412 1012544
    VCID: 387F1BC04BF0A0FE89-806D
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    Address 76: Park Assist
    Cannot be reached
    End-------------------------(Elapsed Time: 02:49)--------------------------
  18. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hey , I'm back at square one with this one .
    Last night car died on me it felt like fuel wasn't coming to the engine. I'm dead in the water with this one .
    Any help please .
    Coding: 0000078
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 125679 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:25:49
    Freeze Frame:
    RPM: 128 /min
    Torque: 96.0 Nm
    Speed: 0.0 km/h
    Time: 0.01 s
    Angle: 0.0 ∞
    Bin. Bits: 00000000
    Bin. Bits: 00000001
    Readiness: N/A
    Coding: 0000020
    Revision: 00H11001
    Coding: 0023170
    1 Fault Found:
    Coding: 00049109
    Shop #: WSC 00046
    Coding: 00208933
    Shop #: WSC 00046
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.45 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 214
    Mileage: 123632 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.30 V
    ON
    OFF
    OFF
    OFF
    OFF
    Coding: 0012624
    Coding: 0012122
    Coding: 0003103
    Coding: 0000692
    Coding: 0000948
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 123632 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:42:30
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:43:11
    Coding: 0000144
    Coding: 0000144
    Cannot be reached
  19. Keithuk
    7,079
  20. ak77
    ak77 Member
    May 5, 2014
    80
    Mk5 GT Tdi Golf
    Perth WA
    Hey Keith, yeah I really need help here , so more options the better.
    I cant work out the 01259 - Fuel Pump Relay (J17)- 009 - Open or Short to Ground....
